ESP8266 how to make a ps4 exploit .bin file to host and flash
That's just to allow the ps4 to load its os
Just like booting your pc runs better when fully loaded
added for method 1 only (13.5mb)
matrix animated (leeful v10 based full exploit nothing missing with animated matrix background)
added esp8266 salt v1 bin for method 2 just flash to your esp8266 4mb bin
this is a custom bin ive made for the esp8266 based on salt's night-king and leeful's menu
7 themes included pick from main menu with date and time
auto just loads the exploit then pick payload and manual is manual
password darksoftware
Noice. Thanks very much for sharing.
Reactions: prb
O wow bro these are awesome prb. Please keep them coming :)
https://mega.nz/folder/S59XAApb#Y2a-OlaPXMzqaMM6-WX2NA
Hello friends, I want to share a small modification, translation into Spanish, that is to the host of lefful v10, leave only the loads that are used the most, at least I wanted to put an image but for some strange reason, it does not apply if there is an expert around here. even more putting the image and converting to esp8266 I would appreciate it very much this version is the one that is applied from pc but hopefully someone will convert it to esp 8266 which is the one that I use the most
can an expert help me out please. I just got this esp8266 and I can't figure out how to use it. None of the 2 current methods that I use on my other one are working. I can see it in Device Manager so......
Amazon product ASIN B0834JQ5Y5
You have no index.html its needed for it to work
Does arduino see it ?
I downloaded it. It has an index file
No just says searching like nodemcu.exe
My bad was looking on my phone lol
Does it not let you select it in board manager
Not at my pc atm I do it in the afternoon
If someone else doesn't do it for you
i have no idea what to select in the board manager. Any ideas?
Si lo subí
is inside the folder the index html
Reactions: kards
friend I have not been able to install the bin in spanisch on my ps4 the cache remains at 36% and no avansa more could you solve it please
try this one it was the cache manifest you had the BG as BG.JPG when it needs to be BG.jpg
also you did not edit html to use the BG ?
ok friend thanks i will try
v10 in Spanish works perfect friend you are super thanks for your help
Reactions: prb
Im doing a work around so we can use the 4mb esp8266 with any size exploit will be posting a tutorial later today
And no no zipping if you have enough space on flash
new method now we can use any size exploit
I love this wallpaper, can anyone provide? Also so beautiful host
Reactions: kards and laz305
prb,
which exploit are u using on method1, with the lion wallpaper? Is it sleirsgoevy's latest?
Thanks
leeful PS-Phwoar! For 6.72 posted it on oct 19th and Sleirsgoevy posted his lastest jb on 5th aug
prb,
No kp at all? stability?
ive had good pass rates with it tbh leeful said it still work in progress
but if you like it for the bg only im going to put out v2 of the salt exploit today with runs on the new exploit and mostly bins also had
to fix a few bits including a couple of new bg including the lion one
SALT V2 (for method 2 just flash to your esp8266)
added quick hen 2.1.3 and 2.1.3b to main menu
fixed a couple of payloads that was not loading some colour changes and now 9 backgrounds
let me know what you think and what you would like to see for V3
It would be badass if you could add spoof to it ;)
ok I have no idea how to get these payloads too work. I have tried both ways. As is and Edit index file to match zipped payloads names, so added .gz to all bin files and nothing works. You skipped a step in this guide man cuz I can't get payloads too work. And it's not my index file cuz it works fine using selfhost.exe
I finally got it working. It’s cuz I was creating a new manifest and didn’t need too lol
Reactions: kards
