ESP8266 how to make a ps4 exploit .bin file to host and flash
ok so I got this with WARNING COMBINE BIN OVERSIZE
so that PS4HAX is the WiFi Name? and laz is the Password?
I was able to make these
***Hidden content cannot be quoted.******Hidden content cannot be quoted.***
Good work mate glad we got there
Reactions: laz305
Have you tried my v10 .bin I've got a slim also
The html I use in my v10 bin is slightly different from the github download it was ripped from leefuls web host I've had good success with exploit + hen 2.1.3 give it a go nothing to lose but do remember v10 is still only just a test from leeful
But to date the best success rate is from his older v6 version on the slim I forgot to reupload v6mod I have to check if it download and exploit is working later today
Tried your v10 but always KP. Back to V9b.
Worth a try I'm using v10 now but tbh I was still using v6 until v10 came out as v8 and v9a and v9a would get random KP
It's well documented that different ps4 have different successes rates like yourself I have a slim mine is the so called v2 version
But good your getting good success with v9
It seems host most stable is now v9.b, haven't had a KP until now, but it can happen randomly as always.
I ve been using v10 with only one kp and that one was because I tried hen 2.1.3, with 2.1.3b 100% success rate ....
(crossing my fingers right now)
actually we haven't yet lol can you please take a look. This is what I'm flashing but when I go to user guide it says can't connect
https://mega.nz/file/DlElVYgb#oTXq8RCVOH3hzzyH6AJ_pcX3pvFovMBswBz-bjPpHVI
https://mega.nz/file/2xlUCKDR#8u2Wds2-Trn96_rrp0dk1CKG2vFeTM0LUhN96hB_-uQ
its working ok for me must be your upload sketch (wifi sketch) did you delete or change anything in Arduino ps4Exploit also option for turning auto hen is working but will not change from off to on (text only not working)
ive also fixed the cache as it was not working
data and pre-made download below
password darksoftware
awesome thanks!!!! I found the problem with auto on & off. at around line 119 replace update autosettingsdisplay with this
function updateAutoSettingsDisp(){
autoexpHen.innerHTML=localStorage.autoexpHen;
autoexpHen2.innerHTML=localStorage.autoexpHen;
AutoColourChange();
Can you you apply the fix and update the download link with it please? no point in having broken stuff available for dl
EDIT: Ok finally got it too cache 100% that dam manifest lol
AutoColourChange();
Ns0LJD4
Ns0LJD4
Bad link is replaced by good links?
Reactions: laz305
Hey I ordered a 32mb esp8266. So now if the total size of a folder is like 10mb do I still have to zip all files? Can I skip that part and just load it as is?
Im doing a work around so we can use the 4mb esp8266 with any size exploit will be posting a tutorial later today
And no no zipping if you have enough space on flash
new method now we can use any size exploit
Reactions: ilie321 and laz305
Wow this is amazing bro!!!! But this new way will still cache to the user guide as well?
No but its quicker as it gets bookmarked
In the web browser
In the web browser
Ok but you can just use Leeful selfhost.exe then. No need for esp8266 this way. Plus I feel I get better results using user guide and I can always start it right away and not wait 1min like we have to do using the browser.
Yes you can use leeful self host only but you need to put your ps4 on the same network so on line using the esp8266 is a closed network offline and why do you have to wait 1 minute dont understand what you mean
It doesn't matter if it run via user guide or browser as both are just a cached web page
Reactions: laz305
Well Leeful recommends that you wait 1min before opening the browser too get better results. But I get the same results in user guide and don’t have to wait the 1min. I updated Black Widow hehe
That's just to allow the ps4 to load its os
Just like booting your pc runs better when fully loaded
added for method 1 only (13.5mb)
matrix animated (leeful v10 based full exploit nothing missing with animated matrix background)
added esp8266 salt v1 bin for method 2 just flash to your esp8266 4mb bin
this is a custom bin ive made for the esp8266 based on salt's night-king and leeful's menu
im calling it salt v1
7 themes included pick from main menu with date and time
auto just loads the exploit then pick payload and manual is manual
