Warring: 5.05 Exploit is NOT SAFE !!!
Status
Not open for further replies.
Warning:the 5.05 exploit isnt SAFE?
i had 5 of my friends had a kernel Panic and their systems got corrupted badly it asked them 2 reinstall the system again and worse it asked to initialize their P$4.I thought it was bcz of the new offline hosted exploit but 1 of them wasn't using it. so if it didn't happen to you today it will happen someday
to sum up some people might have had the same problem but didn't reported it bcz they thought it was a random thing
i know that i might get banned for breaking the rules but this thing is serious as hell >>
1- let's see how many people to report the same problem
2- try to figure the was is the common links between them
3- try to but more info into the subject
4- see what might cause the Hard-disk to fail
5- try to ask the people with enough knowledge about
I HOPE YOU READ THIS AND CONSIDER IT AS A SERIOUS PROBLEM
AS I SAID IF DIDN"T HAPPEN TO YOU TODAY IT WILL HAPPEN SOME OTHER DAY
NOTE !!!
I USED THE 4.05 exploit and it crashed my P$4 like a million times but nothing ever happened - I also used the 4.55 Exploit and never crashed or had KP
the 5.05 Exploit crashed my P$4 but didn't crash my system YET!!!
So again READ THIS AND PLEASE PAY ATTENTION IT MIGHT BE NOT JUST A RANDOM THING !!
ADIME please At least consider this as a threat to all of the P$4s save\data\games
i wish it's just a fake threat and it just a random thing ..fingers-crossed
bcz the worst thing could happen to a gamer is losing their games-save and trophies
what i have notice it crashes when there is a usb plugged in before the hen exlpoit is ran so i make sure nothing is in the usb ports but it its early firmware expect a few bugs
Guys u r missing the bigger picture ? if more people report that the system fails then it's not a ranodm thing
which means that it will happen to all of us at the end
n just think about that " losing all ur data bcz of the KP or Power off or whatsoever"
we are talking about the system failure and asking you to initialize ur ps4
so my question to is have suffered a system failure ? bcz is if u did i will consider ur the number 7 to have the system failure
and nothing was connected to the ps4 as my friends said
Thats the whole point of backing up your databse so its possible to restore everything, I havent heard this happen to a single person yet and I havent had a single crash in 4 weeks of using my system
again dont use rest mode and always close your apps after saving progress
pls. delete this thread. what op says is nothing more than spreading fear. alone that it happened to 5 "friends" of him shows that his story is a little bit overblown.
yes. with a exploit like this there is always the chance of a fuckup happening sometimes but there is no reason to fearmonger like that. at this point we would know already if it is a widespread problem.
i hvn't had a single system failure in 4 months on4.05 or 4.55 or any time in my life even on 5.05 YET
pack up is not a solution if this is a problems and keeps happen to you in the future 3 times a month or even once a month ...Right?
NOOOOO REST MODE .. one of my friends just had a KP for running the HEN and after that KP the system failed to start and he had to initialize his ps4
just turn off after playing games on ps4 HEN, don't use rest mode
again you are missing the bigger picture if it's not a random thing than it's a big thing
your logic is flawed anywas, if it is random its huge issue but nothing is random in electronics world
if it is random nobody could prevent it in the future
data corruption is normal when you exit unexpectedly
co5mo i have a phat ps4 on 4.05 it used to KP like 8 time out of 10 it was really bad but guess what it never failed the system and nvr crashed my data
if it is not random it might be bcz of some bad bugs and could be fixed .. if its random like my phat on 4.05 that used to KP alot
i thought i might be bcz they all had their ps4 full with games
but one of them had a 1TB and only 500gb was only used and his system crashed anyway
what if i told you it can be because of how the new fw (5.x) handles storage and not the kexploit problem hmm
Reactions: sabasoor
co5mo
also offline exploit that was posted for the russia with love guy it might be a reason
but again one of them was using the alazif 0.4.5 and the other was using the stoooged
so i think it has to do with eathir as ur said the system itself or mybe the fpkg dnt go along with the system or maybe the HEN is having a bug since it was only released with one version on 5.05 and it's only 4 weeks old
>> but just think about it if your system crashes once a month wud u like it ? even if u have a back up and stuff
that's why i posted this thread to see if it is a random thing or it happens to more people
it doesn't matter if it happens to one or milion the one occurrence is problem
but what can we do? stop using it? it will eventually get solved and this is not the platform to track bugs and also wrong forum so dont waste your breath
co5mo if it happens to a big number of people devs will look into it
have been there since the 4.05 and devs always listen if it is a big thing and if it is fixable they will fix it bcz i believe they will
and about wasting my breath it worths it if points out to a big problem
it will eventually get solved? mybe if we don't talk abt it will talk more time however if we do talk abt it i might get fixed sooner if it is fixable
Reactions: Thedeleter
No problems so far, apart from the console sometimes crashing when executing the HEN payload (maybe 1 out of 25-30 times). Using Vortex HEN 1.6 online (rest mode is no problem here, but after resuming the game put to sleep it complains about the license and quits, so no real use for using rest mode anyways... I usually use "turn off" instead). Im using ps4adminv5 online or from esp8266/nodemcu
Reactions: sabasoor
did you guys use the early versions of offline host? 4.3 and 4.4 had issues
lolololol this crap funny asf.... 1. nice English 2. when your system crashes it just restores the system storage then it's all good and 3. I Know what you mean even though it hasn't happened to me thankfully but I'm just acting like I don't to piss you off mwuahahaha
this is an exploit, what do you expect? You have all the rights to play legit anytime. No one is forcing you to use this exploit
It doesn't matter if this scares or "tries" to scare people from using an exploit. I have never had any problems with mine. It could be many differn't things. Computer, electronics etc. are made by humans. There for nothing is perfect. There is always going to be some kind of bug or problem with something. If that means you're scared to use the exploit then you really have no business using it anyways since you might not know much about how exploits and such work.
1: Don't use Mira + Hen, neither the official xvortex 1.6. Only use Xvortex Hen 1.6 that comes with alazif host it has uodate blocker removed and works 5 time better. I do get kernel panics but pretty rarely.
2: Never use REST MODE.
Status
