- Mar 9, 2018
- 82
- 4,674
To do this you obviously need a new drive you want to install (it MUST be a 2.5" drive, a 3.5" drive cant fit internally it must be external using a sata cable and a separate power source)
I used a drive i pulled from a Seagate #SRD00F1
Need a set of Precision screwdrivers(a set from harbor freight works fine and is only 5$
Also need the recovery firmware of 4.55(or whatever firmware your ps4 has on it)
