Tutorial TUT gdrive bandwidth limit DL FIX
Make sure that you're logged into your Google/Google Drive account and that you replaced the "/view" to "/edit" at the end of the link in your Browser-URL-Bar.
Thanks, I tried with another link and it worked
In Jdownloader it says download limit reached ? what to do now how to fix this
Follow this tutorial?????????????
Then copy the link of the file in your own GDrive and download it or download.
what tutorial ?
You are posting here in a tutorial that explains how to bypass GDrive download limits. The very first post has instructions that you can follow to fix that issue.
In short the instructions are:
1. Login into your GDrive.
2. Open the original link from the file on GDrive.
3. Use the copy to my GDrive function to copy the file to your GDrive account.
4. Copy the download link of the file from your own GDrive account.
5. Download the file and profit.
Ever even bothered to read the first post?
Reactions: Sparkss
i was asking abt the flex and flic sites download limit ! not Gdrive files
Check your post you made here.
It says "In Jdownloader it says download limit reached ? what to do now how to fix this" and you replied this in a topic about "TUT gdrive bandwidth limit DL fix".
Nowhere have you mentioned anything about flex and flic sites (whatever that is).
What do you expect? Are you smoking weed?
Reactions: Sparkss
It doesn't work when you reach IP-limits even with newly created copies (i found out the hard way two days ago) maybe Google patched the thing and now you need both new copy and a different IP ...or just wait and try again later
hi guys ,
my question is how to download a bunch of links from filecrypt,there saved as google drive links like 45 parts .
i using jdownloader 2
This problem appears" jdownloader download impossible add google account and retry or wait and retry later.
My account ist connected with jdownloader
Reactions: nymlinkin
