Remote play on non-activated PS4 ! method released
Kiru...tanks for d tutorial it works but before I could turn off idu, my console went off and after reboot, I was stucked at please wait, updating id, for like 30mint. I On and off d console, 윤희지hing. I later reinstalled 5.05 firmware recovery..... I try to do d process again but dis time around, it did'nt work bcos remote app exe on my PC is not showing manual way of entering code given by ps4, only searching via internet to connect..the error message is that...I shld "turn of application and features on ps4 for remote play to work".... I even patched d app, same thing......Any solution to this???
No need of reinstall 5.05, if you get updating idu means you are connected to internet. Connect to internet should be off. Then you can enter staff mode with button combo.
You have to use old remote play version and patch it.. just uninstall your version and try with
  • 1.0.0.15181 - Hash : 694659629815D82CDCD62A95FA771237
  • 1.5.0.8251 - Hash : 53DF9F442EEC309D95BE88D28CC21E18
  • 2.0.0.2211 - Hash : FCD0DD66996B399F6A1A9A254F7E85B3
  • 2.6.0.2270 - Hash : 2E4C4CA5ECFD3138CB734ED603958A1 these versions
For patching above version follow https://github.com/MysteryDash/Offline-PS4-Remote-Play/blob/master/README.md
Button combo did'nt work that i reinstalled 5.05.... I try old verion and get back to u....
Did u disconnect internet and once u go to idu mode pls make sure to switch on your controller.(and also if you have activated user2 pls delete it b4 going back to idu again)
Yes, I disconnect...... On user 2 issue, I told u that I reinstalled 5.05 which automatically deleted user2 that activated before and ps4 created a new user2 since I just installed new firmware... Shld I delete it????
Secondly... Since version 2.6 is not working for me, I tried to find other versions but I only got version 1.0.0.15 and it says error to connect.... But I noticed that, version 1.0.0.15 shows manual input of code after patched but nothing like that in version 2.6 after patched... I don't no if there is away I can get version 1.50 or 2.0.0 may one of this versions will work for me..have search almost every sites today, nothing of such. I don't know how to use way back machine to get old application.... Pls is there any links to download version 1.50 or 2.0.0??????
Version 2.6 should work, I download same version and many people have been using it. I wil give u required links + patcher. In the mean time uninstall all previous versions of remote play, clear temp files and also check for any leftovers. Then reboot pc.
Version i used must be this http://www.softpedia.com/get/Internet/Remote-Utils/PS4-Remote-Play.shtml
