Tutorial PS4 Phat/ Slim/ Pro Linux Loader 5.05: Manjaro Linux PS4 [v2]
Thank @codemasterv for this tutorial it is great,but i find this tutorial overcomplicated so i made an easier version that can be installed from windows.
You will need
1. PS4 linux loader
2.My linux image
3.Rufus(2.18 and below)
4.NetCat GUI
5.Usb stick(16gb and above)
6.Usb keyboard and mouse
7.Usb hub(optional)
Tutorial:
1.Download my image
2.Extract the image
select all and click Extract files...
check Keep broken files(it will still work)
Enter the password
Password is:
Go get a burger this will take a while
If it says that a file is corrupted don't worry it'll sitll work
2.Mount image onto usb
Open rufus
Under device select your usb
Next to "Create a bootable disk using" select dd image
Go to disk image next to "DD image" and select file that you extracted
Click start
Go get another burger this will take a while
3. Running linux on ps4
After image is mounted onto your usb plug it into your ps4
Before you send your exploit to ps4 make sure resolution is set to(720p or 1080p,it your resolution is set to 1080i it won't work)
to change resolution go to setting->Sound and Screen->Video output setting->Resolution
Now that you've set your resolution go to mod menu
Click original
When awaiting for payload... screen appears open NetCat gui
Type ip4 adress of your ps4,set your port to 9020,and drag ps4 linux loader below ip4 adress and above inject payload button
click inject payload
And wait
after this there are three possible outcomes:
if it turns blue violet blue it works
if it crashes your device you did not configure resolution so do that
if it turns solid white try again
3.Log in
This system will be in french if you want to change language to english you can find tutorial below
If you found this tutorial confusing this is my first time so don't jugde me.
If my pictures go offline notify me.
Would you like me to compile more linux images?
Thanks a lot man. Your tutorial is the best. Everything has been made easy. Other tutorials were complicated. I have successfully loaded linux on my PS4 pro. Please make more tutorials.
Reactions: Xgame6 and DonB1985
My usb drive is 64gb but it uses only 14.54gb for ext4 partition and leaves the rest 43.11gb unallocated. Is there any way to create ext4 partition using full space?
I'll make it for you for several days
Update:I've got some stuff going in my life right now so I'll make you Linux image when it all gets resolved so be patient
I believe in within Linux itself you can search for gparted and extend the partition, try that.
By the way how is the performance of this build? mine is VERY stuttery, but it is expected, i got only USB2 flash drive...
Well perforamnce all comes down to your USB write and read speed.My 16 gb USB is horrible while my 64gb usb(with much faster read and write speeds) runs greate(dolphin emulator 60fps and cemu 15fps)
hello friend what model of your ps4 pro? the mwu and 7016b and it does not work, it stays white light or it turns off, I've already used oendrive 16 and hd 3.0 external on port two and in the usb with no success, any ideas?
ChreechNorm
Well have you configured resolution of your PS4 pro to 1080p or 720p
Btw stupid question are running PS4 pro 5.05
Do you use hdmi switch
Ya anyone with a ps4 slim cuh 2015a I can't get it to work tried several times I also get a no signal screen with s white ps4 light as mentioned above firmware 5.05
I have been working on getting linux running for almost 14 hours total now and I finally got to a point where Ive made progress. I have my flash drive formatted and the image's loaded and my usb is in my ps4. I sent the payload and my ps4 screen went black and the light is blinking blue- Whiteish violetish - blue, but nothing is happening from there. My screen is still black and my light is still blinking. Is it supposed to take longer than 10-20 minutes to load? (ps it is a fat model ps4, resolution is 720p, running 5.05) @BataBo
Dear @alpha35 the problem is in your tv.
I had the same problem when I ran Linux on my old tv but when I bought my new tv everything was working fine so if you want this issue fixed you must buy new tv.
Reactions: alpha35
I have that on new android tv ps4 keeps blinking white blue for half hour then i stopped it because it must be loaded in 5 to 10 minutes?
Verstuurd vanaf mijn GT-I9300 met Tapatalk
If it's blinking blue violet blue that means Linux is running and if you get no visual output that means your tv does not support Linux.Im sorry.
Btw is there a difference between violet and purple
On one of my screen i can't see terminal loading sequence.
I wait on that monitor 10 minutes approx and than I'm inside the system, no problems.
Load the OS and than wait :)
