PS4 Cheats Fpkgs & Exploit Host By JgDuff
INFO FOR ALL!
All Codes, Patterns, Cheats Fpkgs And The Sharing Of All The List Is Completely Made By JgDuff.
Good Game To All Of You! :)
To Watch The List, Click HERE
INFO FOR ALL!
may i ask sir if the crossbow bolt bug is included in the fix? i encountered it new game after firing the crossbow to an enemy then trying to recover the used bolt the game freezes.. it wont let me pickup used bolt.. even walking toward it freezes..
@jrkilat :
Read dear friend...Read!
--->Game Fixed :
  • Days Gone - CUSA08966 & CUSA09175 & CUSA09176 & CUSA15027 [v1.51]
Items & Ressources Are Finally Fixed. All Cheats Are Tested On +or- 20 hours Of Gameplay.
All Work Fine Now. (You Know, Iron Mike And Diamond Lake Mission)
...You Can Have "Freeze" If You Continue Your Game With These Cheats
Above The Old Ones. If It Your Case, Just Start A Fresh New Game
. (Sorry For That!)
...more than 20 hours of gameplay with my two favorite guns...Crossbow and the great shotgun.
...And all the others cheats activated in the same time...During more than 20 hours... No freeze! 0!
...And PS dear friend, you have all infinite. Why you want to recovered your used ...bolts ?
...It's weird but you will have no freeze.
Reactions: DastanDark02
Hi jgduff I cannot Mary assassin grade odinssy game with update
My problem is with the last step when I try to build the pkg it's show euros on 35 of building
about days gone I do have problem right now im on mp3 player Mission when I try to take the MP3 player it's show me Max
@Ghfjg :
Shortcut your destination path the most possible like "C:\Your game.pkg".
You not know how to integrate and remary and you report a problem ?
...Days Gone work! Check your step.
I personnaly test it since the beginning to more than 20 hours of gameplay!
You can't have max if you have just 1 or 0. The items,ressources or keys item
are not infinite if you have just 1 or 0...Check your step or read the message
just above yours!
...And please use "Google Traduction". The language you use is broken or freeze
when you press "Send". ;)
I know how to marry
I didn't this before for Resident Evil 2
and days gone it's the first time I have problem with Mary game with update
Param sfo param lmage0 total size larger than maximum
Could not open or write image file data ps4 acd greece 43 dl
@Ghfjg :
Okay! ...But Days Gone need to be integrated before remarry and Resident Evil 2 too.
You have chance if you only remarry RE2 and it work... You not follow the step carefully.
(You not describe the right Method)
I think you not really know. Check your steps!
...And first of all, shortcut your destination path.
Reactions: vickysivia
Hi @jgduff,
Your kind help needed for this.
I am Re-marrying Last of Us CUSA00556 with Cheats [1.00 Patched Into 1.01]. Base game version is also 1.00
But getting this error. [I done re-marrying others game with same method and its work fine]
Paths are also short.
@easy :
Just before you built the package in "Orbis-Pub-Gen",
go into "Setting/Package" and in the tab "Application Type", choose "Freenium App"
and continue to built your package as usual after this step. ;)
mafia 3 CUSA03617 1.09 cheat didnt work when you try to buy guns from dealer please fix it
@yass22er22 :
The problem you report have no sense with the codes i make.
It's just impossible. Check your built step and read the "Info & tuto.txt" file.
@yass22er22 :
It's just impossible. Check your built step and read the "Info & tuot.txt" file.
thanks for response
what is the relation between built step and what i said
i always reads Info & tuot.txt
all cheats worked fine but i cant buy from dealer any gun even after installed back to normal pkg
@yass22er22 :
What is the relation ? ...All!
It's an integrated update version. If it's not make correctly,
the code can work on certain game but not work properly during all the game.
...PS : I finish this game with the same ID. I love the music of this game!
@yass22er22 :
i love the music too
of course i intergrated the update correctly as i did before with many games using your tutorial
i will delete the save and begin fresh game may be the old cheat cause errors
