PS4 Cheats Fpkgs & Exploit Host By JgDuff
@nguyenbaviet :
Nioh work perfectly (100% No Problem, 100% No Freeze) !!!
You not integrate the update into the game base (Full Game)
and is just after that you can remarry the cheats.fpkgs for this title.
(It's not a Standalone Update but Integrated Update...It's mentionned on the "rar" file)
(And i explain all that in the tutos)
Please read carefully before sending anything.
You make me bad pub and it's not good for others who see my thread
when everything is tested and above all 100% functional.
Read carefully all the tutos please!
Have a great day
Hello my bro!:)
Sorry for the problem. I'm new, and use google transt to write articles.:giggle:
I use FW5.05.
1/ My game
+ "Nioh CUSA07123 EUR v1.00.pkg" MD5 check: 5FAD30C5B9112F4966B5236C96EFED0A
+ "Nioh CUSA07123 EUR v1.21 Update.pkg" MD5 check: 034A19ED6E1118071A8F8EB5936F8708
2/ I download
CUSA07123 For Base Game :
5E29748F03D367ED02469AB52825EA49 (1.21)
Update Version Integrated In The Game Base v1.00
https://uptobox.com/73dvjmqtphxh
3/ I tried to install all patch. Unfortunately at the end of the installation I had an error CE-36434-0. including file Nioh - CUSA07123 - Back To Normal v1.21.pkg
4/ I Re-marry its (I have done many times with success and failure. If it fails, it cannot be installed and had an error CE-36434-0).
5/ when successful, i have a file "Nioh - CUSA07123 v4 - Cheats v1.21 - remarry.pkg" Md5 check: CDFBA872391FE7A3FDE4C9655F999DCB
6/ After successful installation, I logged into the game. And the game freezes on the first screen (Image of Williams). I waited 15 minutes and still couldn't get into the game. Only way to turn off the application. Tried to reboot, rebuilt ... but failed. I have to reinstall update 1.21 again to be able to enter the game (Of course there's no cheat)
Please guide me. Thank you for everything!:thumbsup::thumbsup::thumbsup:
@nguyenbaviet :
All you describe is mentionned in the tuto...I can not say more explication on this subject.
You describe a lot of bad mishandling that comes from your side in your message
and the "error CE-36434-0" ....Again, is mentionned in the "Very Important Info" tuto
and How To Find The MD5 Code Of My Base Game (Full Game) tuto too.
...Just read please. I can not repeat again and again everything
that is already mentionned just because you not want to take a look
and especially, individually.
If you talk in french, go into your MP for infos and tutos in french.
...I just not have the time and it's for that reason that i create all theses tutos.
(I work in the real life. All that is just a biiiiiig past time since 2 generations.)
I know you'll get there if you take the time.
I learned all this without any help or explanation.
It's just a passion and I'm not a developer, believe me. ;)
Take care and have a good day :)
Is it possible to choose which cheats will be activated? Because I didn't want to use the monster hunter world infinite item and palico xp cheats, just the stamina, ammo and reload cheats...
Hello JgDuff!
Thank you for everything! We have the same passion for PS4 and you're the one who goes ahead, guiding the people behind. And thanks for the times that answered my question!
I have carefully reviewed your instructions, including the Re-marry section and the "Very Important Info" section.
and How To Find The MD5 Code Of My Base Game (Full Game).
I have successfully created the file Nioh-CUSA07123 - install V0121.pkg with 50gb. When installed, the display information is 1.00 into the game then 1.21. However, when installing your pkg versions I still get the error "error CE-36434-0"
Maybe I have to find out more.
@nguyenbaviet :
Sorry but retry dear friend. You miss something.
I make the code on this ID "CUSA7123"....It's tested and (re)tested...
And i (re)install all the game and cheats on my PS4 just for you and just to be sure at 100%
....and as i already said, everything works fine...100% fine.
Check on your side.
Take attention on the name of the file in the video tuto.
(Is it an Update.pkg, Cheats.pkg or install pkg(Base Game) ?...etc)
(Is it Orbis Pub or Orbis Pub MODDED, GenGP4 or GenGP4 MODDED ? ...etc)
Once learned, it's very easy, believe me ;)
EDIT :
Hello JgDuff!
If you created your "Full game with update inside" and it work in your PS4
and it really in v1.21,
(v1.00 in the PS4 Info is normal but check in the "PARAM.SFO" if the "Master Version" is really v1.21)
(Re)Mary all the "Cheats.pkgs" and the "Back To Normal.pkg" with your new "Full game with update inside".
If you really make all that correctly, you never have the same MD5 Checksum than in the list
because it's YOUR personnal "Full Game" YOU have create.
It's the reason why than you absolutely need to (Re)mary all the "Cheats.pkgs" and "Back To Normal.pkg"
What you describe in your message about it is not correct.
@jgduff
I have followed your instructions, and the results are incredible.
1 / I made my own pkg cheat v4 version. [Error] result Format of the param file is not valid. (sce_sys / param.sfo, unexpected Application Version (APP_VER))
PS: Although I have succeeded many times, this is the first time I encountered this error.
2 / Also using the above, this time I use "Duxa's PS4 patch repackager 7.2.18.exe" to create pkg with your cheat and my file - "" Full game with update inside ". Make a file new "Nioh - CUSA07123 v4 - Cheats v1.21 - remarry-V0121.pkg"
As a result I have successfully installed.
Thanks again for everything, I'm now ready to explore Nioh.
@nguyenbaviet :
In the past, i make a video for Duxa's too ...Proof :
But i delete it and i return to "Orbis" because "Duxa's" takes too much time to finish the work
and can have lot of problem than "Orbis" don't have when you built something.
...And each pkg take a very long time to built.
With "Orbis", the first "Pkg" of a title is very long but NOT the next of the same title.
The next take 2 minutes and in Duxa's, always 1hrs!!!
Make your choice
and enjoy now :)
EDIT :
Just one last thing.
If you using your files to insert the cheated file inside, you not totally understand the method.
Try again with an other title next time. You not need to take your files.
Except for the game and sometimes the complete update (Not Patched),
all is included and all is tested. (All work fine for (Re)mary step.)
For the tests, i'm not alone ;)
Oh! And for your files, just the "PARAM.SFO" could have been fixed(Proof Of Your Bad Step).
Not all the files.
Orbis told you what was the problem in the files...Duxa's, mmmm not really! ;)
(Just an info.)
---->Info For All 16 Nov 2019!<----
Cheats Fpkgs For New Titles :
[Creation Of Cheats Patterns & Cheats.Fpkgs By : JgDuff]
To See The List, Click HERE
Have A Good Week-End ;)
Monster Hunter World CUSA07708
MD5: 1A694D30FC364F275CA008D01EACDF30
Cheat V2
Sometimes the game freezes when using normal ammo, only with normal ammo does the game crash, but not always, with other ammo it works normally, fishing also freezes the game. (Light Bowgun)
@JessWill :
Are you in v2.00 ? If yes ensure you have integrate the update into the game base.
If it the 1.01, ensure your full game have in, the "Real 1.01 integrated" and not just v1.00
only.
For this, check with "Orbis-pub-chk" or "Orbis-Pub-SFO" or "PS4 Pkg Viewer"...etc
in the section "Master Version".
If you are in real 1.00 and not real 1.01, is the reason of the freeze.
Same thing if you not integrate the update into the game base (full game).
Tell me what your version is please.
@Yahoo2018 allias @Yahoocool, stop with that.
Its the second year that you attack me constantly, even after several explanations spread over time.
Please stop! It's not very respectful and we had you pointed out on PSXHAX
do you remember ?
Please stop now. You know since a long time that i do not take requests.
Thank you to finally understand and respect the work do here.
Have a nice day and take advantage of what is already available ;)
Reactions: danielvasques
@jgduff
I am in version 2.0, i will integrate the update following the tutorial, thanks for the answer
Ok!
I loss my time.
@Renato412 :
Monster Hunter v1.01 not have any problem of broken weapon in melee.
-I installed the full game (With real official 1.01 already inside) on my PS4
-I installed my "Cheats.Fpkgs v1.01" v1 and v2 after for my tests.
(My cheats.pkgs is already (re)married with my base game (Full Game with real official update 1.01 inside) )
- I play the game since a "New Game" (No Save game on my PS4 but is not important)
...All work fine after 2 hours of gameplay. No broken melee weapon.
Your method for built and (Re)marry is maybe correct dear @Renato412 but you
probably not in "Real Official 1.01" in your game base (Full game).
I can send you a video to proof than all work in 1.01 if you want.
@JessWill
Now, i check v2.00 since 1hour (+or-) and no freeze!
I shoot again and again in all sense for nothing with normal ammo,
light bow gun....No! No freeze for now.
It's a very big work to make all that.
Each return for problem need a lot of time too.
It's a lot of delay for me.
It's very appreciated when there is really a problem
but not when is just a bad attention or the file are is not building properly.
You can take lot of way to make your "Pkgs" work but just
one is the right method.
Please read and view carefully all the tutos.
When you integrate an "Official Update" into a base game (Full Game),
the base game (Full Game) can have any version when it's for
integrated an "Official Update" inside". It's not mandatory to be in 1.00.
If it the standalone version, just (re)marry it with your game base (Full game)
and install it like an official update after.
Finally, after 1hour of gameplay on v2.00, i think and like in my tests
in the past than all work like before.
I continue to test it again 1 hour but if i not have a freeze,
i can not fix anything....It's logical. ;)
A friend on Undergunz tested it on my demand in 2.00
today and no problem for him too!
(It's one of the guy make the final test before sharing since month ago)
Same thing than @Renato412, i can send you a video for proove it.
It's long but it avoids obstinate.
Have a great day at you two.
EDIT : (For @Renato412 & @JessWill)
No freeze in v2.00 and no problem in v1.01.
  • Tested by me in v1.01 and v2.00 on 6 hours of gameplay at total (16 Nov 2019)
  • Tested by my friend on Undergunz on v2.00 on a couples of hours and no freeze on
    2 confirmations.
    (16 Nov 2019 First confirmation at 2:07PM and second confirmation at 6:32PM)
EDIT 2 :
Now 3 confirmations today on v2.00 by my friend (17 Nov 2019 At 12:34PM)
All work 100%
@vickysivia :
It's a thread for PS4 here. My list of "PS3 Cheats.pkgs" is on others websites
but i not update anymore for now. To much work on PS4.
I not have time to play with a game just to give you an exemple.
I already explain all this in pm dear Vickysivia.
Thank you for your understanding :)
@JessWill :
4th confirmation of my friend for Monster Hunter CUSA07708 v2.00.
(18 No 2019 At 9:27AM)
After several test, YES! You all right! The game freeze at certain place.
Ah! Now i'm happy. I'm not totally loss my time ;)
I check it soon as possible!
