PS4 Cheats Fpkgs & Exploit Host By JgDuff
@FireRat :
(Re)Uploaded! :)
Reactions: FireRat
@EmuBoarding :
For Delete The Stats In The Top & Bottom Of The Screen Press "L3+Touchpad(Right Side)"
Go To "Display/MsgCon..." And Activate "Disable FPS".
...For Delete The Others Stats In The Bottom, Press "L3+Touchpad(Right Side)"
Go To "Tasks..." And Activate "Suppress Active Task Display".
Return Into The Game By Pressing "Touchpad(Right Side)" 2 Times.
That it! ;) (...And same thing with Uncharted The Lost Legacy.)
...It's not marked in the "Info & tuto.txt" file ???
@NERO12 :
(Re)Uploaded! :)
@EmuBoarding :
@NERO12 :
(Re)Uploaded! :)
Yes,,, is there! Sorry!
Thx Alot!!!!
Reactions: jgduff
@jgduff I tried to merge the base game with the Call of duty Vanguard update, but a corrupt data warning appears when starting the game. When i install the game without merging it, the game works normally. What tool pack do you use to extract and merge the base game with the update? Can you make it available?
@Olecram :
I mentioned it 1 or 2 weeks ago :
INFO FOR ALL!
I have to apologize at @Psykos!
I had integrated the update of "Call Of Duty Cold War" and it was refused because
the limit of "100000MiB" for development. (In the build part)
It's not "orbis" which causes the limit but the game and its
"chunks" files that are programmed not to exceed "100000MiB".
(You can see it during the build)
I say that because i build others games with more than "100000MiB" before.
So, for this game, the solution is :
-Go to "CUSA24267/zone"
-Delete all languages files you not use and keep only your language and the english .
Be careful to delete only languages files starting
by the letter of their respective languages.
(Exemple 1 : "it_cp_nam_prisoner" Is An "Italien" Language File)
(Exemple 2 : "cp_it_siege" Is NOT A Language File)
(The Other ID of Call Of Duty Cold War not have this problem of limit if you prefer.)
Sorry @Psykos! You have in partly right!
I check that for the future .
Have a nice day! :)
EDIT :
Vanguard ???
Oh! It's not the same thing! ...I mentionate it too lol!
Take the last "Orbis-pub-gen v3.87" to extract and build your stuff.
1 "GenGP4-app.exe" to make "App or Integrated update" and 1 "GenGP4-patch.exe" to make "Patch or Remary Of Any Patch".
...And the same "Orbis-pub-gen.exe" to make "Patch" and/or "App"! ...More simple!
Download the last version v3.87 here :
Can you please reupload this PS2 games @jgduff , thanks.
Freekstyle - CUSA99925
Maximo Ghosts To Glory - CUSA93599
Maximo Vs. Army Of Zin - CUSA93699
Shinobi - CUSA52525
Virtua Fighter 4 Evolution - CUSA88833
WinBack Covert Operations - CUSA88855
Hi Jgduff is there any chance for Far Cry 6 cheats and Mass Effect Legendary Edition cheats please.
@Olecram :
Have a nice day! :)
EDIT :
Vanguard ???
[Hidden content]
I was able to merge the base game with the update, however, when using the cheat pkg, the campaign mode is locked again. When the cheat pkg is not used, the mode works normally.
@kerrar :
(Re)Uploaded! :)
@Olecram :
The Codes for "Zombies Mode" is the same than for the campaign mode. (Like Cold War).
If it work for the "Zombies Mode", it work for the campaign too.
(PS : Campaign mode need all campaign DLC and DLC does not contain ".bin" and others files i need to create codes patterns.)
I think you make something bad in your build steps or your game not have a "Keystone".
You absolutely need the "Keystone" with the new "Orbis-Pub-Gen v3.87".
Finish the time you can make a "Fake Keystone". Check that on your side.
Or... (Re)Install all the "Licence" after you have installed the "Cheats.pkg".
(I think not but it costs nothing to try.) ;)
IF ANYBODY CAN CONFIRM THIS PROBLEM OR THE PROPER FUNCTIONNING PLEASE!?!
Reactions: Olecram
@kerrar :
(Re)Uploaded! :)
@Olecram :
I just checked the built game and the file is present in image0/sce_sys/keystone.
@Olecram :
In the official package you not have touch???
Ok! I need confirmation because i working on it and it work perfectly in my tests. I not understand your problem
and i already work hard on another title for now.(Not have the time to go back again just for checked that so....)
...To saving a precious time! :)
And if problem he have, thank you Olecram to have mentionate it. ;)
Reactions: Olecram
Hello !!!
I had installed "Call of Duty Vanguard CUSA24041" and with or without the cheats the game did not work (padlock).
Since JgDuff has put the version "Call of Duty Vanguard - CUSA29092" (no padlock) everything works with the cheat and the
same for the zombies mode !!!
A big THANK YOU to our dear JgDuff !!!
Reactions: jgduff
@Mikado :
Big thanks for your help my dear friend! :)
@Olecram :
Your version ID is she CUSA24041 ?
Reactions: Mikado-06
@Olecram :
Ok! I finished trying in every way "Call Of Duty Vanguard CUS24041".
The problem is active with or without cheats.pkgs and "Integrated" or not.
You did not mentionate the problem like that at all leaving thought than it's the cheat.pkg...!
The problem, after a lot of tests(Lot of times too), come from the DLCs and the Licences.
You could have made your own tests for that dear Olecram...
...The right DLCs and Licences is here :
