- Jun 14, 2018
- 623
- 55,339
It's not caching offline, it stops at 14%. Previously worked fine.
Thanks for letting me know, i messed up with offline cache, it should be fixed nowIt's not caching offline, it stops at 14%. Previously worked fine.
Just to report that Webrte always shutdown the console. Other than that all works fine for me.sleirsgoevy 702 v2 webkit fix added
you can now load HEN while offline
I figured out that no webrte expolit works on 7.02 yet. The only one that let me use ps4 trainer, injecting webrte.bin payload with a program called ps4 punch like netcat was https://ps4macedo.github.io/702/ (version 7), didn't tried the new version 8 yet. I only needed webrte to crack nioh 2. I usually only use your hen.I'll fix this later
V3
faster getting jailbreak
Done.. thanks to him for working WebRTE payload but I haven't tried it yetI figured out that no webrte expolit works on 7.02 yet. The only one that let me use ps4 trainer, injecting webrte.bin payload with a program called ps4 punch like netcat was https://ps4macedo.github.io/702/ (version 7), didn't tried the new version 8 yet. I only needed webrte to crack nioh 2. I usually only use your hen.
Edited: well tried the https://ps4macedo.github.io/702/ (new version 8) & webrte works flawlessly without manually inject the webrte.bin payload. So, maybe you can take a look at it & see what Macedo did to make webrte work on 7.02. No worries though.
It works now, but it took me about 30 min to get the hen working. Previously was faster. Well, after test probably all available hen for 7.02, I can say that for me, macedo's hen is the fatest, it always need 2 max 3 memory fails to work.Done.. thanks to him for working WebRTE payload but I haven't tried it yet
I fixed some things there idk if it fix the problemIt works now, but it took me about 30 min to get the hen working. Previously was faster. Well, after test probably all available hen for 7.02, I can say that for me, macedo's hen is the fatest, it always need 2 max 3 memory fails to work.
