Tutorial NSW upgrade to 12.0.1 Firmware including ALL files. Atmosphere,Hekate,Firmware
Atmosphere and Daybreak.nro will be used to upgrade
In this tutorial i will show you how to upgrade to firmware 12.0.1 and atmosphere to the latest version without burning fuses. I also made an allinonepackage rar file . ( it contains everything you will need. i.e { sigpatches, fuseeprimary, hekate bootloader, Daybreak homebrew app and even the FIRMWARE file} you DO NOT NEED TO look for sigpatches. they are included already
This tutorial will be made with the safest method possible. Daybreak.nro i will NO longer user ChoidjourNX. in other words the file you will download will only be compatible with daybreak.
How to prepare for the update : DO NOT Proceed if you havent done this
1) make sure you uninstall any themes you might have installed with themeinstallerNX
BEFORE proceeding ahead. if you havent installed any themes go ahead without worries.
2) if you have a game cartridge INSIDE your switch take it OUT.
3) If you have any tesla modules or cheats well disable.
on with the tutorial below
[Hidden content]
[Hidden content]
Enjoy.
Things you should know about​
IF you want to play game cartridges your sysnand and emunand have to be in the SAME FIRMWARE VERSION
here is a picture of Tinwoo homebrew app in case you people dont know
thanks
[Hidden content]
[Hidden content]
Enjoy.
[Hidden content]
[Hidden content]
Enjoy.
thanks
Work great for me. Finally switch from SXOS To Atmosphere.
How can I update Atmosphere when a new version is out?
Same question for a new OFW update?
Just watch this thread @DorianX12 will update when necessary
That's what I do he always provides all necessary files like daybreak app and so on that's needed for updating ofw
Plus the best thing is you know it's safe coming from @DorianX12
Would there be a tutorial to go from this 12.0.1 to 13.0 eventually? Thanks!!!
Can anyone provide a tutorial on how to switch from SX OS Pro to Atmosphere so I can play the new Metroid?
Thanks, it works!
one thing that I forgot was to use RCM jig on my switch
and does it safe to delete 12.0 folder after completed?
absolutely i can help you.
i need more info tho.
what step are you on? did you download the files ?
i download your all in one package ,
i remove the old atmosphere ,sept,ect. file forme the root of my sd card
i run tegrarcmgui, i install the driver (it's the first time i plug the switch in PC)
i select the fusee primary provided in the all in one and when i try inject payload i got an error (rcm-7 and sometimes rcm-8)
(step 4 ) Sd card is in the switch and tegra recognize the switch with the rcm ok message
