EUR AU Littlstar VR Cinema - [CUSA-06742] [NoPSN]
I have been looking for this for a few days as i am new to 5.05, i downloaded the two packages via the russian site on the last page and it works perfectly for me with noPSN. THANKS!
I upload the download again
LITTSTAR 1.18 No PSN
Link LITTSTAR no psn.zip
:English:
Install in order
1. EP2870-CUSA06742_00-LITT1ST4RTHEG0AT-A0100-V0118.pkg
2. EP2870-CUSA06742_00-LITT1ST-PATH-A0100-V0118.pkg
Internet connection is needed.
When starting the program, two options, VR mode and Normal mode, start the normal mode.
If you do not let you create the account from the app, do it from the browser in the url: https://littlstar.com/
:Spanish:
Instalar en orden
Se necesita conexión a internet.
Al iniciar el programa, sale dos opciones, modo VR y modo Normal, iniciar el modo normal.
Si no os deja crear la cuenta desde la app, hacerlo desde el navegador en la url: https://littlstar.com/
:English:
Install in order
:Spanish:
Instalar en orden
Thanks so much for re-posting this! Any chance there is version 1.22 with the live rss feeds?
Reactions: dst and Jacken
i tried, tried tried.. still stuck with the logo turning in dark. deinstall, reinstall, quitting app, relaunching, rebooting, starting without camera,. no way i could run it on ps4 pro 5.05. does this install requires to have a preactived psn PS4 ?! & what about the 1.14 version which didnt require connexion ?! is there somewhere the old PKG ? ...
you dont need activated psn but you need to have internet connexion to work
the app need to connect on internet for use it
and i dont know why but i need to start the normal and not vr edition. but work with vr
Hi ! Any progress on other methods of activating this app ? I dont want to wipe my HDD in order to use it... but i would like to use ;D
Kamil Temp you dont need tu wipe your hdd.
look my post over your last post. you dont need activated psn to use it
thats right you just need to block updates wirh dns and hen blocker, then install the moded pkg and let the prgram connect to the net
Littlstar ha muerto, a ver si alguien puede hacer un pkg del nuevo RAD, o encuentran alguna otra aplicacion que haga lo mismo
Segun puso alguien la 1.14 no requiere internet, esa funcionaria?
I tried vs 1.18 on 5.05. Internet but no psn. It hangs on the loading screen after skip account.
Edit: Has anyone tried the pre-activated profile method for this? It seems to be a UK profile, yet I'm from NA.
pre-activated profile method? how?
