Tutorial How to get your DLC/Themes from PSN and make them installable
So this method is for DLC with extra-data?
or for dlc without extradata?
@cephyx
I've read Zer0xFF's auth_info dumping write-up, and he says that the method is valid for both games and apps....so i'm asking myself and if for game/DLC that doesn't work like FFXV and Nier we try dump the original auth_info??
@cephyx
I'm not even completly sure if it's a psn check for these games. But I don't think it will work, their method works with the decrypted files (eboot.bin?) and we can't change anything since all the files are read-only on the disc. Sure, we could dump the game, but then the official DLC pkg would not work. Only if we had the game + dlc both decrypted maybe it could work? I don't know.
Reactions: Goldenboy22
Reactions: Nimaiya
That did absolutely work!!!
I used your tutorial to reactivate previously downloaded Lego Dimensions DLC packs
I created the _installfirst package, then reinstalled the already installed DLC,
Unfortunately, the psDLC could not retrieve list of DLC for a given game (ERROR: The request was aborted: The connection was closed unexpectedly.)
So I used long process
thanks
EDIT: upon using psDLC, that generates 128KB files (that are not working), using Fake PKG Generator I was able to reactivate my DLCs. each generated file was 1856KB for LEGO Dimensions
Reactions: cephyx
Works perfectly. Was able to get killzone Shadow Fall DLCs extracted
Unfortunately, since the new store I guess, "pkg" is not more selectable in psDLE. I am able though, with psDLC to connect and select the DLC I need but once I click on "Create FPKG", I get a "sc.exe is missing or invalid" error (sc is in the same file as psDLC). This guide sounds golden, but nowadays, it doesn't work anymore.
EDIT: Never mind, it still work like a charm. The "sc.exe" error was my mistake
how did you get the psDLE to work?
I still don't know for psDLE. I thought of something and I'm gonna try it later. PsDLC work with DLC without extra data, haven't tried yet wih extra data. I'll keep up updated
Ahh I see, for some reason psDLE won't show the DLCs and Themes I wanted to dump perhaps there is a more updated way. Thankyou very much!
Yes I have tried already and it did the trick thankfully
How you managed to do this? Tried to use old ps store with valkyrie extension and it just doesn't work. Trying to get a link to purchased pkg from my account.
