GTA Native Resolution Patch for Adrenaline released
  • Thread starter Thread starter Deleted member 535
  • Start date Start date
D
Deleted member 535
Guest
screenshot-png.161152
TheFlow has just released an Adrenaline plugin that increases the two PSP GTA games' internal resolution to 950x544, aka the PS Vita's native resolution, as well as including mipmap patches to increase the textures' overall quality. This comes with a slight tradeoff, however, as the game will run at a slower framerate (around 20 FPS instead of the original 30) and 16 bit color depth instead of 32 bit. Nevertheless, the end result can indeed look impressive, as you can see from the screenshot above!
The plugin requires Adrenaline v6.9 and, as previously stated, supports both Liberty City Stories and Vice City Stories, specifically:
RemasteredControls which will enable you to use both analog sticks while playing the game. This last one is also compatible with a few other titles, so you may want to read more about it if you find yourself playing many PSP games on your modded Vita!
Source
Reactions: Leeroyb14
