you will get a fail at the end of setup just press ps button and goto to the user guideI have a fw of 6.72, I had an exploit before it c0d3m4st4_ESP8266XploitHost_v2.84b
and it works for me
what bin are you using ?this is how it works but when loading the cache
write it to me at 98% error installing cache
- Publicaciones fusionadas automáticamente - ¡No publiques dos veces! -
Leeful PS-Phive! estilo Prb personalizado agregado
*** No se puede citar contenido oculto. ***
[/ CITAR]![]()
Hola buenas si no es mucho pedir y puedes hacerme este host con el fondo de un unicornio que a mi hija le encantan, gracias de todas maneras por el gran trabajo realizado
From my own experience, I can confirm that there are no KPs in current 7.02 implementations (online host + offline cache), only a few retries after getting insufficient memory messages. It is safer than previous exploits (I had several KPs on 6.72, one of them killed my PS4 Pro hard disk).
Which host are you talking that gives no KP, I have just upgrade to a new 2 TB Hdd and want to keep it healthy without damn KP
aqui tienes mi amigo[QUOTE = "prb, publicación: 142170, miembro: 26053"] 7.02 V2
más cargas útiles en este
envíame el fondo [/ QUOTE]
Hay te e puesto uno pero si ves tú otro que quede mejor ponlo a ella le da igual lo que quiere es un unicornio ok , muchas gracias
Here you have a few of them:
https://hakkuraifu.github.io/PS4xploit/
https://night-king.ir/ DNS: 5.56.134.56
https://dmiller423.github.io/
And for ESP8266:
Esp8266 Host v1.1 fix (7.02) by BaNdZiOr
https://t.co/Hg7KhTMxxM?amp=1
as I've already saidThanks
1 to say 7.02 has no kp is a myth yes no doubt its less likely then 6.72
2 problem with 7.02 is that all current host are basically the same nothing wrong with the exploit it's the webkit that needs work
3 If you only play games and you don't really use different payloads just hen then its fine
Hello again friends I would like to know if someone from this group can build me a .bin for my esp8266 from the host PS-Phive! _v1_SelfHost is translated into Spanish in the folder there are two images, anybody can use it, thank you and help me I take many hours translate it but not build .bin I would appreciate it https://mega.nz/folder/X5tEhICb#wnPCzEOA7S8S_fjF2nT44Q
[QUOTE = "prb, publicación: 142573, miembro: 26053"] 7.02 usuarios tienen auto jb + hen y montones de cargas útiles
[/CITAR]![]()
amigo, ¿puedes crear un .bin para mi esp8266 traducido Leeful PS-Phive! completo al español pero no lo hago bin deja una imagen si puedes ponerla te lo agradeceria un saludo https://mega.nz/folder/X5tEhICb#wnPCzEOA7S8S_fjF2nT44Q
