- Jun 6, 2018
- 109
- 71
Yes I am using the latest hen1.6,still the same..maybe my external hdd is the problem..I will try to use another one.reset your ps4
are you using the latest hen payload?
hen1.6?
use a different hen payload..maybe
Yes man tried the full initialization yesterday,still the same error..maybe my external hdd is the problem.Or try to initialize your PS4 (Install 5.05 Recovery)
Yes maybe my externall hdd was corrupt,I will try another one later.@PirateofPC yep, he should check his PS4 Internal HDD First on PC for Errors before installing the recovery, maybe the HDD got corrupt
is everything working out for you bro?Yes I am using the latest hen1.6,still the same..maybe my external hdd is the problem..I will try to use another one.
Thanks for the advice man,appreciate it.
Yes man,I’d tried to use another external hdd and UFC3 was successfully installed..I was currently downloading the nba2k18 now and hopefully it will install successfully..is everything work out for you bro?
np, same here bro?Yes man,I’d tried to use another external hdd and UFC3 was successfully installed..I was currently downloading the nba2k18 now and hopefully it will install successfully..
Thank you for all the advice man.God bless
