Store login with 5.05 firmware
Pir8pete
8
5
Is it possible to login to the store when on firmware 5.05?
so every time Sony releases an fw update, the store with force you to do the update on the system before it lets us login? dam that sucks
is there no way this can be spoofed? if I'm on 5.05 and spoof 5.55 to allow the login
No!!!! We dont know the new Passphrase required for access to the network. this can only be obtained by exploiting the latest firmware and dumping it.... However no Dev with such an exploit has done so or is likely to do so.... in short unless someone with access to a jailbreak on the latest OFW decides to share this with us a spoofer will not enable access to the PSN. it will only spoof the version number.....
So, SAMU needs to be cracked.
Reactions: Karol
