PSVR Connect to firmware 7.0
Mrpi
55
24
Hey guys,
Just wanted to know if there is any Problem in connecting the psvr headset to a non hacked ps4 with the updated firmware 7.0. Is there any software drivers transferred to the psvr headset?
Can I connect my psvr headset afterwards to a ps4 5.05 with no problems? Thank you!
Just be careful not to update the firmware on your VR headset. If you update it to a new new version, then it might not be able to connect to 5.05. So I would just leave the headset with v5.05 just in case.
Its not possible to play latest firmware PS4 with PSVR on an older Firmware. It worked I needed to update PSVR and used latest HEN and it worked.
Reactions: dbacello
So to confirm again, any version of PS VR (Both Gen 1 and 2) can work with PS4 5.05 as long as we are using the latest hen?
