PS4 Cheats Fpkgs & Exploit Host By JgDuff
please share Shadow Of The Tomb Raider Definitive Edition - CUSA10872 - Cheats v2.00
without Infinite Health .. the games becomes silly with god mode
Reactions: Kitaismith
The real issue with Infinite Health in Shadow of the Tomb Raider Definitive Edition is a different one: whenever you fall into the depths, you don't die and you get stuck in the game. Sometimes you can continue playing from the latest checkpoint, but most of the time you can't continue playing and you have to close the game and start it again.
@jgduff, could you have a look at this sometime? Or maybe create a second cheat file without Infinite Health if this issue cannot be fixed?
@jgduff
I have The Last of us
CUSA00556
MD5 : D9317ADA3DE8E9B431604A4DCB7C5CC3
I have the base game and also the v1.09 update, both files are seperate, not integrated update.
There is a stand alone cheat that you've graciously provided: CUSA00556 [Standalone Update]
So does that mean I just install the base game ==> v1.09 Update ==> CUSA00556 [Standalone Update] ?
I've checked your instructions in the first pages but not still sure if I've missed something, just wanted to confirm.
Thank
@satelman :
Just press start before you fall. Load the last checkpoint.
Don't let Lara's death animation. Hit Start as soon as you know she's falling...That it.
I tested the tricks and it work perfectly.
@ronaldyo85 :
Stop sending your crap on my post.
It works for you, keep it for you or share it on other "thread".
..I'll end up having a bunch of people telling me something's wrong
and it won't even be my "Cheats" but I will still spend hours trying to fix the problem like a dumb for nothing because of all this.
INFO FOR ALL
Stop all your ... request.
You mention if it works or not!
I do not change the codes as you wish because of petty thieves at left and right (TylerMOD is a good example!).
It's for my children at the base. Don't forget it.
The tutorials took me hours to do. Read them and watch them carefully.
Stop trying to get raw in your mouth for lack of patience and ask me nonstop.
I think you find it hard to imagine the time that all this takes and above all, the fact that I am human
And that I fail to provide your many endless requests.
I am not a factory! Nobody pays me for this. I have $ 3 of donation and it's ok, all is free at the base
but... Do you really think it's worth all this free work?
Calm down your requests and take the time to appreciate, try, test your problem if you have problem...etc.
Just yesterday I was asked NFS Heat, I answer that he is in the list...I receive no thanks.
Instead I got "Ok! Do you have Rage 2 ?"
I make cheats.pkgs" and lot of codes since 12 years old now.....But...What wrong with this generation ???
Please become a little more adult human and less spoiled children.
I will surely be insulted for this message but I challenge you to try the adventure and you will understand.
Thank you at all! (The world really change in 12 years...Request, demand and insult!.. Majority of the time!)
what is wrong with you .. i shared the link because it is all your effort .. i always appreciate your work
be calm and dont attack for nothing
games with infinite health are silly and unplayable ..just remove it and make another version as you did in most of your cheats
have a nice day dear jgduff
Hi 'Jgduff ' U r PS4 fpkgs cheats
Marvel's.
Provide PS4 Base Games Download links
@satelman :
@ronaldyo85 :
INFO FOR ALL
I am not a factory! Nobody pays me for this. I have $ 3 of donation.
I make cheats.pkgs" and lot of codes since 12 years old now.....But...What wrong whit this generation ???
@jgduff So, is it that easy after all? Just hitting Start as soon as I know Lara is falling?
Great! Thank you. All Shadow of the Tomb Raider Definitive Edition cheats work OK, then.
Thanks again for this and the rest of your cheats! Your hard work is much appreciated (even if you're not told often enough).
Take care.
Reactions: jgduff
has anyone seen warning like this before or something similar:
[Warn] param.sfo: Param Image0 Total Size: larger than maximum (57757Mib > 50000Mib)
Got it when using orbis-loader.exe to merge base game with an update.
INFO FOR ALL :
Click Here To See The New Release
@jgduff
JgDuff could you explain me in Shadow of the Tomb Raider
The game crashes in the middle of the game with error CE-34878-0
And go back to XMB.
I have had this 5 or 6 times. I am in 6.72.
However, I have the game with the same MD5. ???
@Mikado-06 :
I haven't had this problem but at the same time i can't play for long
on the titles that I offer therefore, i will check all that. Thanks for the feedback. :)
EDIT :
How much play time approximately ?
@jgduff
Thanks for your answer. I have about 30 hours of play.
The first CE-34878-0 errors started at La Cité Perdue.
But I don't know if it's the game or the cheat?
Hi, @jgduff
Here you have some more feedback about your cheats for Shadow of the Tomb Raider Definitive Edition.
I have noticed a small but annoying issue: While exploring the area of the city of Paititi, the game freezes randomly and unexpectedly, and it is necessary to close the game and start it again.
Are you familiar with or aware of this issue? Is there a way to fix this problem? (apart from deactivating the cheats, of course). This happens to me only in Paititi, not in the tombs or other areas of the game. Strange, isn't it?
@jgduff
JgDuff In the end I uninstalled Shadow of the Tomb Raider which I had put in external DD with app2usb and reinstalled internally and played 6 hours and finished the game without problems !!! :)
Reactions: jgduff
@Mikado-06 :
This is what I thought. After 4 hours of play, I still don't have a freeze.
Thank you for this feedback. It saves me work for nothing.
...Just 1 question, which "App2USB" do you use ? The one in my exploit host ?
Take care dear Mikado-06 :)
@satelman :
You have your answer ;)
@Mikado-06 :
@satelman :
@jgduff, I don't think so. This is not my case. I have the game installed internally and I have never used App2USB (I don't have an external drive). I'm using c0d3m4st4_ESP8266XploitHost_v2.84g and Mira (unofficial).
The question is: Have you discovered The Lost City (Paititi) yet and have you tried walking around doing different things such as retrieving objects, talking to people, etc.? Here is where the game freezes at random. As I said before, this does not happen in the rest of the game, only in this area.
@satelman
Hello . Yes of course I made the Lost City "Paititi" and it is in this region that the game crashes randomly with error CE-34878-0 and return to XMB. I saw on the forums that it is an error frequent on PS4 and it is not due to the cheat. After reinstallation I was still on "Paititi" and I had no crashes.
Reactions: jgduff
