Problem launching zelda botw WITH dlc
aye420
10
3
Hello to anyone who read this, first i apologize for my English as it is not my first language.
Well, here's the problem, like the title says, i can't get my botw to work with both dlc's.
The game works fine with last update or base game v0 but when i install the dlc's no matter what game update it is or firmware btw the game crash and exit at home menu 1s after i launch it.
I use Atmosphere latest version atm 10.2 S with Horizon in version 8.0.1 i tried different version of Horizon too.
Obviously i reinstalled the game from other files as well, chech the hash's for the files, titleID.
I should add that i use a micro SD with exFat (tested) but my other games work fine or i reinstalled them so i don't get why this peticular game would bug like if anyone could help thanks
without error message or error log we need to resort to the following
1)unistall the game and updates.
2) install base game run it and create a save file
3) install updates one by one then run the game ( see if it runs without crashing )
4) install DLC #1 run the game ( see if crashes )
5) install DLC2 see if it runs
also where did you get the DLC files from ?
remember. game version has to be compatible with the DLC.
i know you stated that you are running latest BOTW update. list here the version of that update
Hello, i already did those steps except that i have already my old save on my switch.
The game works without updates, with any updates and with one of both dlc doesn't matter which one. When the both are installed it crashes and the error message is "The software was closed because an error ocurred".
I tried installing the whole game on my nand and i have the same problem.
Edit : I'll try to enable log option with Hekate and see if it catches anything because right now no error code and atmosphere doesn't crash.
Reactions: antigravitee01
so you are trying to load a save file that was created on an specific version of the game ?
not recommended .
since you did not answer my questions "where did you get the DLC and update files "
go here
get the updates and DLC again (they arent that big anyway you can get them quick)
then make sure if you are loading a save file that it has to be on the same version . updates. and DLCs. in which it was created
not recommended .
go here***Hidden content cannot be quoted.***
Sorry i didn't saw the question, i got them from darkumbrella and various torrent sites. I'll try with those files but my save worked like a charm from 1.5.0 and even when i tried on the same version that didnt change anything.
to me it looks a lot like on of your update files is the problem. below is a picture of how my perfectly working BoTW looks like along with verision #. i got it from that thread i mentioned up above
I have the exact same files ID. For the DLC's and the update, same versions too.
I'll try with new files and if it doesnt work i'll try with a new save and keep you updated
I got the files from a legit, reliable, known uploader. ( sorry to say this but you got them from torrent and that leaves a lot of room for mistakes and corruption)
2) that save file.
create a new one just for testing purposes. once everything is legit load it with edizon or checkpoint what ever you use.
2) that save file.
Hello, i tried everything, base game works with updates but same problem when both dlc are installed the game crash at start. i tried with a new save, i launched the game between each update and i tried different version of the dlc still the same problem...
@aye420 none of that makes sense.
send me a pic of your game version,
run the game and withing the game take a pic of your game version.
@dorianx12 I know.. here's the screenshot, as you can see it's the latest version
unistall all dlc, game updates and base game. also delete all tickets for BoTW
go to that link i gave you above.
download base game ( i know its a big game and you already have a working copy) BUT i have read similar threads in which files from different sources have not let NSPs work. example base XCI and NSP updates (yeah yeah I know thats how it should work with game cartridge and DLC and updates) but the point stands ( from different sources)
I went ahead and install reinstalled the game today, with DLC and game updates in order to try to emulate what your problem is, it worked just fine no issues in my end with the files from the link above . there is no reason why it shouldnt work for you if you are using the same files I AM USING>
Hello i saw your reply and downloaded everyfile again from your source and the update file and everydlc, installed with quark and goldleaf usb worked like a charm but i still have the same problem.
I tried both dlc lot and it still does the same with both pack. The v0 doesnt work tho the game don't let me launch with it but it boots..
I deleted everything with every update before ofc and rebooted the switch to be safe. The game still crash's when launched it makes no sense...
Update : I tried a lot of things and none worked so had to nuke the whole nand... I did the reset with the hombrew : Haku33 since i didn't want to do it with the settings. Formated my sd too and reinstalled the whole thing now it fucking works. Thx for helping out
