need help on 5.05
timmyb
14
16
hell all. i used modded warfares tutorial back in august to mod my ps4. i installed 5 games ,and got real tied up running my restaurant. it has closed now because of covid so i have lots of time to play. i see that 6.72 is out now as well. i hooked my ps4 up to try and play some 6.72 games made to work on 5.05. i instantly ran into a problem. when i load my exploit page, it loads, but when i click on hen or mira or any of them, it does load the package it jsut spins. any suggestions, should i follow a guide an update to 6.72. i tried to reinstall my hack, but it errors out. its still on 5.05.
hey there @timmyb you might want to go ahead and clear cache and reload the dns,if your running backports you still use the ps4 section on the dns and select hen.if you want to update you might have update blocker installed, you would have to download the 6.72 update pup put on a usb drive and install in safe mode to keep the games you already have installed. if you need further assist please join us on discord ^_^
