USA NBA Street: Volume 2 - [SLUS-20651]
sabin1981
PS2onPS4 Lover!
986
26,237
Game Name: NBA Street Volume 2
Codebreaker Injected: NO
Widescreen: NO
Title-ID: SLUS-20651
The game works fine, both extraction and install. If you're getting install errors on PS4; reboot (I've noticed HEN can sometimes go a bit screwy and installing can sometimes throw a C5 error) and if you're getting errors on extraction then you need to use WinRAR 5 or above, or something equivalent that supports WinRAR v5 compression.
Reactions: rawaf11
i will try to download it once again and see if its working or not tnx anyway
It's definitely working, I redownloaded it from those links myself, just to make sure, before I posted that it was working :D Good luck!
If anyone is looking for this in the future just use ps2-fpkg v.06 It's easy.
1. get the ps2 iso
2. open ps2-fpkfg as admin
3.make a txt file name it whatever you want.
copy this into the txt file.
--vu1-no-clamping=0
--vu1-clamp-operands=1
--vu1-clamp-results=1
--gs-adaptive-frameskip=1
# Fix for graphical corruptions, require "JAK" emu.
4. in general tab load your iso and background(1280x1080) and icon(512x512 pics you want
5.. in the emulator settings tab add your txt file you made
6. hit create create fpkg
good luck
Reactions: Hxmoudx
