- Jun 21, 2018
- 978
- 9,284
Click on a thumbnail to see more pictures for Metal Robot Spirits -Side MS- Mobile Suit Gundam Wing: XXXG-00W0 Wing Gundam Zero (Re-run)
Features
- Material: ABS, Die Cast, PVC
- Height: Approx. 140mm
- Limited availability
- Actual products may differ from photos.
Description
New Mobile Report Gundam W, the leading aircraft Wing Gundam Zero appears in the METAL ROBOT soul.Wing Gundam Zero appears from the METAL ROBOT soul. Sharp modeling, precise painting expression, and heavy die-cast parts are used for a high-class finish. Furthermore, it is equipped with gimmicks such as opening and closing without replacing the machine cannon and transformation to the neobird form.
