USA Mega Man X - Command Mission - [SLUS-20903]
sabin1981
PS2onPS4 Lover!
986
26,237
Game Name: Mega Man X Command Mission
Codebreaker Injected: YES
Widescreen: YES
Title-ID: SLUS-209.03 / NTSC-U
Issues: None I've noticed.
Notes:
This game has been injected with Codebreaker. When you first run the game on PS4 it will run uLaunchELF, allowing you to run Codebreaker and select cheats for the game should you so wish.
  • Press O to load File Manager.​
  • Navigate to "CDFS" and then "--ELF--" folder and run CODEBR~1.ELF
  • Codebreaker will launch and allow you to select cheats for Mega Man X Command Mission
  • Once you've selected your cheats, press START (right-side of trackpad on DS4) and go to the disc icon.​
  • When Codebreaker asks you to "Please Insert Game" just press X to launch your game with cheats applied.​
  • The game will reboot to the uLaunchELF menu. This time rather than opening "--ELF--" folder, simply scroll down the list and select SLUS_209.03 to run your game :)
If you don't want to use Codebreaker at all, just run SLUS_209.03 from the "CDFS" menu and skip "--ELF--" altogether.
Mega Man X8 is fine, but X7 is unplayable --- unless you don't mind having voices be a garbled mess and music being sped up in tempo by about 700%. I don't recommend it :)
wow, these are all gone. it says online but no luck. i just found out about your releases. will try downloading your others. hope this gets reuploaded some day. i happen to have the PAL widescreen patched of this title but yours with the codebreaker is a great addition.
Widescreen: YES
Notes:
How do I download this game first time user.
