Input/Lag after running HEN
KenD90
8
0
Hey guys, i'm not sure if i'm alone in this. When turning on the ps4 the menu and disc based games run fine, but after i run HEN the ps4 menu and games will have this weird input lag but inputs will drag and respond weird at random times.
As anyone had this issue and if they had it, were you able to solve it?
Any help would be appreciated. Thanks
I get it sometimes when I send a lot of payloads, switch games often and generally play for hours on end. I just restart the console when that happens. I've never had it happen right after loading HEN though.
That's strange. It's always happening after i run HEN. Games that require quick inputs are basically unplayable now.
Try these DNS settings:
168.61.128.158 (Primary)
165.227.83.145 (Secondary)
Then, instead of running HEN, go to PS4 RTE's and choose Tylermod, it will load HEN and JK patch.
See if that helps with the input lag.
Gave that a go and unfortunately creates more input lag :(. Is it because i'm located in Australia or something?
which games are effected?
Yeah maybe try to cache the hack files and then run them offline.
If that doesn't help, I'm really all out of ideas except to go the hardware route with that USB thing you can use to host the exploit.
Is there a youtube/guide up to date that you recommend? I'm not too familiar with the cache thing.
