GoldHen 2.3 plugin AFR problem
dade80
AKL Member
12
201
I have a problem with the Goldhen 2.3 AFR plugin. I use it to apply MODs to Resident Evil games. But when I activate it, every time I start ps4 and Goldhen, I lose all installed DLCs and bonuses, and I have to install them again before using MODs. Why?
Davide
Which are you using the host as a website for this?
Try Goldhen 2.4b14, I had no problem with it, and IIRC Goldhen 2.3 doesn't support AFR Plugins (Correct me if wrong).
Reactions: Senkuu Aoki
Thanks for your reply... i'm use host karo with 6.72 firmare. But I think I found the problem...the games are installed on external harddisk... and in another post on this forum, someone was asking why the DLCs disappeared... the solution was to disable the harddisk and then re-enable it... and in effects it works... maybe there is another method
I am glad you found a solution and fixed this issue!
@CapKLD Thank you for helping him!
Reactions: CapKLD
