USA Front Mission 4 - [SLUS-20888]
sabin1981
PS2onPS4 Lover!
986
26,237
Game Name: Front Mission 4
Codebreaker Injected: YES
Widescreen: YES
Title-ID: SLUS-208.88 / NTSC-U
Issues: None that I noticed.
Notes:
This game has been injected with Codebreaker. When you first run the game on PS4 it will run uLaunchELF, allowing you to run Codebreaker and select cheats for the game should you so wish.
  • Press O to load File Manager.​
  • Navigate to "CDFS" and then "--ELF--" folder and run CODEBR~1.ELF
  • Codebreaker will launch and allow you to select cheats for Front Mission 4
  • Once you've selected your cheats, press START (right-side of trackpad on DS4) and go to the disc icon.​
  • When Codebreaker asks you to "Please Insert Game" just press X to launch your game with cheats applied.​
  • The game will reboot to the uLaunchELF menu. This time rather than opening "--ELF--" folder, simply scroll down the list and select SLUS_208.88 to run your game :)
If you don't want to use Codebreaker at all, just run SLUS_208.88 from the "CDFS" menu and skip "--ELF--" altogether.
My man, Thank you so much for this! Such a great game. Will you be doing Front mission 5: Scars of war Eng Patched?
