Fatal error after udating to 16.1.0 please help
jimbone007
24
2
I updated atmosphere to 1.5.5 today I did everything correctly except I forgot to put the new fusee.bin file into payload folder on sd. I bottied up the switch by injecting the new fuse.bin and in settings it said I was on 1.5.5 then I used daybreak to install 16.1.0 and everything went fine when the switch went to restart I got a fatal error message and now everytime I try to boot it up using tegrasmash I get the same error wether I try to inject the fuse.bin or if I try to launch out of hekate. I replaced the fusee.bin in payload folder on the sd with the correct one but Im still getting a fatal error. How do I go about fixing this?
Post automatically merged:
I finally figured it out. For anyone else with the same problem the error will give you the folder title and then go to atmosphere/contents and delete that folder the error mentioned and that's how I was able to fix it. Works great now and all up to date!
