First some context:
* My switch is using a default emuNAND setup with stock OFW and Atmosphere 13.1.0 as CFW.
* SD Card is 256GB and formatted as FAT32
My problem:
I am trying to set up the emupath in the bootloader 'hekate_ipl.ini' file as follows (both config and stock segments are in the file but ommitted here):
When I boot my switch, he does not take that setting into account and does not use my switch folder or 'hbmenu.nro' from the 'emuMMC/RAW1' directory as in the config, but instead crashes with error code indicating he does not find a resource.
The reason (I think) I know this is that, when I put that folder and file into the root of my SD card, it does properly work without any issue.
Tried with and without the additional lines of the emupath and the emummcforce, but does not change anything unfortunately.
Does anyone have an indication what could still be wrong here or possible steps I could take to resolve it?
Thanks in advance for any help offered.
My problem:
For reference and added info, in below also my emummc.ini from the emuMMC folder:[Atmosphere CFW]
payload=bootloader/payloads/fusee.bin
icon=bootloader/res/icon_payload.bmp
emupath=emuMMC/RAW1
emummcforce=1
[emummc]
enabled=1
sector=0x1a2b8000
path=emuMMC/RAW1
id=0x31574152
nintendo_path=emuMMC/RAW1/Nintendo
