Ce30005-8 error please help
nasir
6
While installing a pkg, midway theough i get an error called ce30005-8 error. Please helpp
Any game above 30 gb go es this.
Any help would be appreciated
same but i get another error message after few secs trying to install a game CE-36244-9
btw did you solve it ?
That is a common error for a possible bad hard drive or Blue Ray drive. It is unfortunately a generic error as well. If you have a spare hard drive laying around you can download 5.05 firmware to a USB stick and swap your drive out to see if it is the Blue /ray or the Hard Drive.
It is also possible that you have corrupt data. Try removing the install via FTP from the download directory and reinstalling the game that is crashing during install.
this happened to me once and apparently the external hdd that i used to install the game from is the culprit.. after changing to a different external hdd i can install the game like normal... next time be careful when unplugging the external hdd, unmount it before unplug it just like you do on the pc..
