AUTOMATICALLY Jailbreak your PS4 9.00 with a Raspberry Pi Zero W or 4B!
Prices for Rasberry Pi have gone through the roof. So unless you already own one this method isn't worth it.
That's understood, was considering a esp board. I don't want to get something that either dosen't work or is to expensive. So a link to a compatible board from a chinese site be useful, im prepared to wait for delivery
Is there a way to auto jailbreak with an ESP8266?
Yes, here you go:
https://github.com/stooged/PS4-Server-900u
I have done this using wemos d1 mini and with nodemcu and use it onw 2different ps4's .
You will need 1 1k ohm resistor. 1 npn transistor, 1 usb pen drive, and a wemos d1 mini - total price is less than £5.
Wemos d1 mini is an esp8266 board and hosts the web access point, once the JB payload is sent - one of the pins connected to the pen drive is set high and then set low (same as plugging in and unplugging the usb drive), then goldhen is automatically sent.
i dont see how this is a auto jaillbreak as you have to start the user guide and choose goldhen where is that auto jaillbreak
No you don't. All you need to do is open a www webpage and everything else is done automatically.
It will automatically perform the automation upon startup. See the auto jailbreak section of the video.
Valid point but you can get "premade bundles" that include them if you need the extra parts.
