I was looking at AppsToUSB.ini It says the following....
When using skip drive and mulitple drives at the same time you need to specify the intended mount point of the usb hdd.
your first drive should be 0 and second drive should be 1 ending at a maximum of 7.
this will prevent the payload writing usb0 links to the usb1 drive if the mount points switch on the console.
MOUNT_POINT=0
Just so I understand correctly
When wanting to move pkg's to my 2nd Drive
1. Add MOUNT_POINT=1 (Perminantly)
2. Disconnect my First drive from USB 1
3. Connect my 2nd Drive to USB 2
4. Run ApsToUSB (Let it do its biz)
5. Connect the relevent drive when playing a game? This part seems strange. I defo can't have both connected?)
